madger
Oct 25, 2022Tutor
RAXE500 160Mhz
How do i enable 160Mhz channels ?
Oct 25, 2022Guru - Experienced User
When its set to "up to 4800mbps" in the wifi settings, thats 160mhz wide
- madgerOct 26, 2022Tutor
When i go to the drop down for wifi 6 channel select the actual 160ghz channels are unavailable, only 80Mhz channels?
- plemansOct 26, 2022Guru - Experienced UserGot a screen snip?
Also what region are you in? - plemansOct 26, 2022Guru - Experienced User
So its only saying "up to 2400mbps"?
Im in Texas
4800 is set, but im not getting any of the 160ghz channels in the far left column in the attached picture.
