IreneHwang
Jul 21, 2021Aspirant
RAXE500 6GHz network invisible to AX210
Hi community, I already red several posts about 6E problems, but I couldn't find any clue for me. The problem is, as I wrote in subject, AX210 can't detect 6E SSID at all. I'm struggling for ...
Razor512
Aug 03, 2021Prodigy
Is your WiFi radio or OS instal localized to another country where the 6GHz band is not allowed?
That has been a common issue, especiallly for peoplewho imported the RAXE500 into other countries where their regulortory authorities decided to be unfair and not alloy people to enjoy the 6GHz band, thus they ended up with a WiFi router that would broadcast on the 6GHz band but none of their localized client devices would be allowed to even look at that band.
Aside from that, none of the current WiFi scanning apps support the 6GHz band, thus it is realy only visible in the AP list that windows generates.
