IreneHwang
Jul 21, 2021Aspirant
RAXE500 6GHz network invisible to AX210
Hi community, I already red several posts about 6E problems, but I couldn't find any clue for me. The problem is, as I wrote in subject, AX210 can't detect 6E SSID at all. I'm struggling for ...
Christian_R
Aug 03, 2021NETGEAR Employee Retired
Hello IreneHwang,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
IreneHwang
Aug 03, 2021Aspirant
