IreneHwang
Jul 21, 2021Aspirant
RAXE500 6GHz network invisible to AX210
Hi community, I already red several posts about 6E problems, but I couldn't find any clue for me. The problem is, as I wrote in subject, AX210 can't detect 6E SSID at all. I'm struggling for ...
IreneHwang
Aug 03, 2021Aspirant
Hi Razor512 ,
Thank you for the comment.
RAXE500 - imported from US, installed in Korea, where 6GHz is also allowed
Intel AX210 - imported from US (but made in China)
Although the Region in the RAXE500's Adminitration menu is set as North America which I cannot change, I think RAXE500's 6GHz itself seems to have no problem as I can detect and connect well with Samsung S21 Ultra(Korean domestic version).
I'm now strongly suspicious of Intel AX210 driver or firmware becuase I noticed all AX210's 6GHz channels in AX210 are disabled using Ubuntu 21.04 / kernel 5.11. Maybe it could be related with localization or regulation as you pointed out, but I'm not sure yet.
I've requested Intel's customer support but couldn't have proper answer so far.
If you have further advice or comment, it would be also appreciated.
Razor512
Aug 04, 2021Prodigy
In the device manager settings for the AX210, do you have any visible 6GHz related settings, e.g., in the attached image from my AX210?
Image link on imgur in case the embedding doesn't work: https://i.imgur.com/K7qHDGR.jpg
- IreneHwangAug 04, 2021Aspirant
Yes, I can see that 6GHz menu, also the 6Ghz option in the preferred band setting.
To the eye, it looks no problem. But it never detects 6GHz SSID.
I've exchanged antennas and AX210 cards into another one, but still have same problem. Very weired.
