IreneHwang
Jul 21, 2021Aspirant
RAXE500 6GHz network invisible to AX210
Hi community, I already red several posts about 6E problems, but I couldn't find any clue for me. The problem is, as I wrote in subject, AX210 can't detect 6E SSID at all. I'm struggling for ...
7Dust
Aug 04, 2021Guide
Did you see this thread when reading other posts?
Unless you are willing to run an Open connection then I do not believe it is working for any Windows users. Microsoft seems to indicate they will include WP3 with security (WPA3-Personal?) in their next major build release.
"Adding WPA3 H2E standards support for enhanced Wi-Fi security"
Someone estimated that may be around October.
Here are the MS release notes for the future release:
PS.
Did you try setting the 500 to Open on 6 just to see the SSID appear?
- IreneHwangAug 04, 2021Aspirant
Thank you for kind comment
Yes I already red that post.
As you could imagine, I already set my 500 for 6GHz as Open just to detect SSID.
For me, at this stage, Auth doesn't matter and has second-priority.
Just for your information,
RAXE500 and the desktop are in line of sight, within just 1.5 meter.
Antennas are directly connected to the bracket and no coex cable.
- IreneHwangAug 16, 2021Aspirant
Adding short commment just to give small understanding for anyone who has same problem :
In spite of a couple-of-weeks studying and googlnig, I finally failed to resolve the issue and now have a candidate conclusion that LAR(Location Aware Regulatory, Location Aware Roaming or whatever) feature of AX210 is the reason of my trouble.
In Windows, there's no way to change or modify it, especially Country code from AX210, I can't turn on 6GHz of AX210 in Windows environment or can't use wonderful 6GHz capability of RAXE500 with my PC or labtop, although 6GHz is alreay allowed here in my country.
I'd like to appreciate everyone who gave me all the comments and intersts for this issue so far.
- petru44oFeb 01, 2022Aspirant
Hello,
Did you manage to resolve this?I want to buy RAXE500 from US and ordered Fenvi FV-AXE3000 Wi-Fi 6E AX210, Bluetooth 5,2, PCIExpress adapter for PC.
Is there a way to make it work despite the location of your presence?
