Topology
Nov 14, 2023Virtuoso
RAXE500: Apple and Wi-Fi 6E
Apple’s recommended settings for Wi-Fi routers and access points state: "Make sure that all routers on your network use the same name for every band they support. If you give your 2.4GHz, 5GHz, or 6G...
Topology
Dec 12, 2023Virtuoso
RE: "It is disappointing that Wi-Fi 6E on the RAXE500 appears to fail to completely support Apple's Wi-Fi requirements. Maybe this will be corrected in a future firmware release...."
Unfortunately, the newly released firmware 1.2.13.100 on the RAXE500 does not appear to support Smart Connect across the 2.4, 5, and 6GHz bands.
Dec 12, 2023Guru - Experienced User
And probaby won't. Most likely intended to not have 6Ghz under the same unbrella as 2.4 and 5Ghz.
