Topology
Nov 14, 2023Virtuoso
RAXE500: Apple and Wi-Fi 6E
Apple’s recommended settings for Wi-Fi routers and access points state: "Make sure that all routers on your network use the same name for every band they support. If you give your 2.4GHz, 5GHz, or 6G...
Killhippie
Dec 14, 2023Prodigy
My RAXE500 uses the same password put in for 2.4 and 5Ghz for 6E, so if you change the name of the networks to the same for them all and use a strong password across all networks it should work I would have thought, as they are all using the same SSID and the same password and then it should then roam properly. Just a thought.
schumaku
Dec 16, 2023Guru - Experienced User
Yes, similar to Killhippie operating WAX630E among other WAX6xx and a few WAC6xx on the same SSID on 2.4, 5, and 6 GHz. Roaming from 2.4 nd/or 5 GHz to 6 GHz appears to be a little bit delayed - however, this seems to be a client specific effect (various Android and Intel AX210, and a small number of BE200/210 based units). Only the Cuppertino devices issue some odd warnings (my old friendship with Apple?).
