common617
May 09, 2022Follower
RAXE500 as a mesh?
Can the RAXE500 be setup as a mesh to Xfinity xb7/xb8 or even better use the RAXE500 as a mesh to the AX6000 WiFi Cable Modem Router (CAX80). What I would like to do is use a moca adapter to conn...
May 09, 2022Guru - Experienced User
The RAXE doesn't support any kind of MESH mode or configurations. Only Works as a router, stand alone AP or wireless bridge mode client for wired connections in back.
