ChristineT
Nov 16, 2021NETGEAR Employee Retired
RAXE500 Beta FW v1.0.9.72 is available for Testing
Hello RAXE500 Community,
We have a beta firmware available for testing for the RAXE500 that we hope will resolve some of the instability issues that have been reported over the last few months....
Nov 23, 2021Guru - Experienced User
Altsai wrote:
FURRYe38 wrote:
Would be interested to know then why does Intel release Windows 10 and 11 drivers for AX210 6Ghz adapters?
I just downloaded v22.90 yesterday...
I guess it's related to Microsoft. I know WIN10 latest build won't support H2E feature so if you insist to use WPA3-SAE H2E to connect to RAXE500 6GHZ radio, you will need to use either WIN10 beta build OS or WIN11 (only these versions support H2E feature)
If you use OWE to connect, I guess latest WIN10 would work.
What is OWE?
I'll check the version I have however latest Win10x64 (retail that came pre-installed) 2H21 and build prior to that is working with WPA3 on my PC. Has since day 1 with the AX210 adapter I have installed and the NG Orbi router I'm using with WPA3 enabled.
Altsai
Nov 24, 2021NETGEAR Expert
OWE stands for "Opportunistic Wireless Encryption", aka as "Enhanced Open" defined by WiFi Alliance.
