ChristineT
Nov 16, 2021NETGEAR Employee Retired
RAXE500 Beta FW v1.0.9.72 is available for Testing
Hello RAXE500 Community,
We have a beta firmware available for testing for the RAXE500 that we hope will resolve some of the instability issues that have been reported over the last few months....
golways
Dec 23, 2021Aspirant
Hi all,
I live in France and, till now, I was not able to detect and use the 6GHz band on my Samsung S21 ultra.
I installed the new firmware on my RAXE500 (bought in the USA) and unfortunately, it did not change anything for me.
Will a new firmware be necessay to "open" the 6GHz band in France ? If yes, do you know when this new firmware is available ?
Franck
Altsai
Dec 26, 2021NETGEAR Expert
golways wrote:
Hi all,
>>>>>> S21 ultra does not support WiFi 6E. Only S21 Ultra 5G support wifi 6E. And France just opened 6GHZ band so would still need samsung to release new image to support 6E for S21 Ultra 5G.
Franck
- randallokweiDec 27, 2021Aspirant
A few observations:
On the 6ghz settings, if i choose a XX(PSC) channel, i am not able to connect mobile or any devices. If i choose one without, i am able to connect, as well the devices can see the SSID of that radio.
Seperately, after running for some time, it takes a reboot before devices can see the SSID for 6ghz.
My laptop with a genuine AX210 adapter, running Windows 11 Pro saw the 6ghz one time and were able to connect. After a reboot of the machine, i a no longer able to see this network again. I have removed the adapter physically, removed ghost entries in the registry, and re added, with no luch.
- golwaysDec 28, 2021Aspirant
Thank you for your help. I do have the Samsung Galaxy S21 Ultra 5G. I hope Samsung January firmware update will able 6GHz band use (if it is disabled). Do you thing a firmware update will (also) be needed on RAXE500 side to unable 6GHz band in France ?
- randallokweiDec 28, 2021Aspirant
I also have the S21 Ultra and Pixel 6 Pro, and they both work flawlessly.
