ChristineT
Jan 19, 2022NETGEAR Employee Retired
RAXE500 Beta FW v1.0.9.78 is available for testing
Hello RAXE500 Community,
We have a beta firmware available for testing for the RAXE500 that we hope will resolve some of the instability issues that have been reported over the last few months....
mbc1965
Feb 04, 2022Guide
Is the Firmware for the RAXE500 the same as the RAXE450?
Feb 04, 2022Guru - Experienced User
Though FW versions seem to be the same, not sure if the actual model #s vs FW model versions will work. You can try loading it and see if the router refuses it. If it won't accept it it should let you know.
- avtellaFeb 05, 2022Prodigy
It won't, there will be a different board id.
- mbc1965Feb 06, 2022GuideThank you!
- AltsaiFeb 07, 2022NETGEAR Expert
>>> just rename from RAXE500 to RAXE450 that should work.
- mbc1965Feb 07, 2022Guide
It worked! Thanks for the tip!!!
- FURRYe38Feb 07, 2022Guru - Experienced User
Enjoy. 📡
