ChristineT
Jan 19, 2022NETGEAR Employee Retired
RAXE500 Beta FW v1.0.9.78 is available for testing
Hello RAXE500 Community,
We have a beta firmware available for testing for the RAXE500 that we hope will resolve some of the instability issues that have been reported over the last few months....
Feb 04, 2022Guru - Experienced User
Though FW versions seem to be the same, not sure if the actual model #s vs FW model versions will work. You can try loading it and see if the router refuses it. If it won't accept it it should let you know.
mbc1965 wrote:
Is the Firmware for the RAXE500 the same as the RAXE450?
