ChristineT
Jan 19, 2022NETGEAR Employee Retired
RAXE500 Beta FW v1.0.9.78 is available for testing
Hello RAXE500 Community,
We have a beta firmware available for testing for the RAXE500 that we hope will resolve some of the instability issues that have been reported over the last few months....
Tonkinite
Feb 16, 2022Luminary
The ISP is Xfinity and the cable modem is a Netgear CM1000.
Yes, a factory reset has been done and the original settings restored, though I've never seen this make any difference.
The computer is connected directly to the router via Ethernet, and the browser chosen doesn't appear to make any difference, but I usually use Firefox. The Admin panels simply do not load in the expected way, often I need to refresh several times before the panels load normally. If I just wait, often panels are simply not filled in, and the router eventually times out the connection.
I'm seeing frequent similar problems with my Lutron smart hub, which is also directly connected via Ethernet.
Use of an intermediate switch does not seem to make any difference.
Feb 16, 2022Guru - Experienced User
How many devices do you have connected to the router?
Same thing happens if you turn them all off accept for the wired PC?
I'm not seeing this on mine. Using MS Edge. Mines in router mode though with only 6Ghz broadcasting at the moment.
- TonkiniteFeb 16, 2022Luminary
Two smartphones and a smart tablet (3 wireless)
Two desktop computers and one laptop (2 wireless, 1 wired)
5 TV boxes, two Roku boxes, and two flat screen TVs, one Blu Ray player (10 wireless)
12 HomePods (12 wireless)
5 WiFi cameras
3 Netgear ReadyNAS units (3 wired)
4 IP Cameras (4 wired)
2 wired switches
Miscellaneous health devices (5 wireless)
So 37+ wireless devices and 10 wired ones, if they were all going at the same time, which of course they are not, as it's just me using all this.
My previous R9000 didn't have a problem with this setup, and it likely has a slower processor, and the configuration is 95% identical, It'd be nice to turn off the 6GHz band on the new one to match but that doesn't seem to work for some reason.
I haven't done exclusion testing yet, but if I had to guess, I'd bet on this being due to the WiFi camera traffic.
- avtellaFeb 16, 2022ProdigyProbably has nothing to do with the CPU as the R9000s Cortex A15 is actually more powerful. The Cortex A53 in the RAXE500 is a successor to the low power Cortex A7 and performs close to the A9. The A57 is the A15 successor. The A53 in the RAXE500 does have superior crypto accelerator though.
- FURRYe38Feb 17, 2022Guru - Experienced User
See if turning OFF all cameras changes anything.
What browser are you using?
5 WiFi cameras
2 wired switches
