M5f10
Dec 05, 2023Aspirant
RAXE500 blocking netflix youtube
Had it connected for 8 months with no issues. Now can't access Netflix, YouTube from Xbox, iPhone, or Android. Not sure what to do.
Dec 05, 2023Guru - Experienced User
Did anything change on the router? If not, doubtful it's a router issue.
Does Netflix work on a different device or can you access Netflix web page on a PC?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Might contact Netflix or MS.
- M5f10Dec 06, 2023AspirantNothing has changed. Netflix and YouTube work fine on my Verizon cell data devices, but try to use wifi and Nothing. Happens on Android phones, iPhone, Xbox ps5. I'll try the reset. Thanks
- FURRYe38Dec 06, 2023Guru - Experienced User
Any Armor or Parental Controls enabled?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Let us know how the reset goes.
- M5f10Dec 06, 2023AspirantFirmware v1.0.11.94
Modem is for Optimum Arris CM8200
Yes the NG router is connected
Did a reset, and netflix works now, but still not youtube
