M5f10
Dec 05, 2023Aspirant
RAXE500 blocking netflix youtube
Had it connected for 8 months with no issues. Now can't access Netflix, YouTube from Xbox, iPhone, or Android. Not sure what to do.
M5f10
Dec 06, 2023Aspirant
Nothing has changed. Netflix and YouTube work fine on my Verizon cell data devices, but try to use wifi and Nothing. Happens on Android phones, iPhone, Xbox ps5. I'll try the reset. Thanks
Dec 06, 2023Guru - Experienced User
Any Armor or Parental Controls enabled?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Let us know how the reset goes.
- M5f10Dec 06, 2023AspirantFirmware v1.0.11.94
Modem is for Optimum Arris CM8200
Yes the NG router is connected
Did a reset, and netflix works now, but still not youtube
