CodenameFalcon
Apr 30, 2025Aspirant
RAXE500 bridge mode issue
I just recently purchased the RAXE500 to use as a WiFi bridge mode Ethernet adapter. The problem I am having is the devices connected to our do not receive separate IP addresses. They ate all passing...
schumaku
May 01, 2025Guru - Experienced User
A WiFi wireless bridge would be for connecting two Ethernet segments over a WiFi wireless link.
The problem I am having is the devices connected to our do not receive separate IP addresses. They ate all passing through traffic with the same IP as the router itself is assigned. Is there a way to allow the bridge mode feature to function in a truly passthrough manner so that all the connected devices receive IP's from the parent router on the network?
So what you really need might be a Wireless Access Point (technically a WiFi<->Ethernet bridge), allowing to let wireless clients associate and the Ethernet LAN. Change your RAXE500 to Access Point Mode!
CodenameFalcon
May 01, 2025Aspirant
Hi schumaku,
What I am trying to do is connect Ethernet only devices to the network over a wireless bridge. This Netgear router is what I'm trying to use as the Ethernet bridge. Access point mode broadcasts a WiFi network which is not what I'm trying to do. The router can connect to the existing Wi-Fi network just fine. The issue is the devices connected to it via Ethernet do not receive separate IP addresses from the parent router.
