CodenameFalcon
Apr 30, 2025Aspirant
RAXE500 bridge mode issue
I just recently purchased the RAXE500 to use as a WiFi bridge mode Ethernet adapter. The problem I am having is the devices connected to our do not receive separate IP addresses. They ate all passing...
michaelkenward
May 01, 2025Guru - Experienced User
The "bridge mode" term is confusing and depends on the context. For a modem/router, for example, it means turning off the router bit and using the thing as a bridge between a router and the Internet.
There is also a "wireless bridge mode" for routers, connecting two routers over wifi so that the second router can "host" devices.
The RAXE500 does not support "wireless brdge mode".
You could follow the advice from schumaku. Wire the RAXE500 to your router in AP mode and away you go. If direct wiring isn't possible Powerline Ethernet might work.
Disclaimer: Just another user with time on their hands.
The RAXE500 has wireless bridge mode. I know mine does.
