Ethan_Kuo
Mar 02, 2022Tutor
RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN
Hi As subject (RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN). So, I would like to know the NAT is only support device connected with LAN cable? Here is my test...
- Mar 14, 2022
Dear all
The problem is solved by network setting cause by our internal gateway setting. (for special reason the setting of gateway is not same as DHCP server if unit want to connect to internet.)
and 2nd is check the ip in router (RAXE500) to make sure that can find it and the IP is correct.
Thanks.
Mar 02, 2022Guru - Experienced User
What device are you trying to "pass nat" on?
What modem/gateway is the router connected to?
What firmware is on the router?
- Ethan_KuoMar 10, 2022TutorHi
Thanks for your reply.
1. The Device is notebook and service is FTP or http .
2. The router is connected with adsl modem.
3. The firmware of router is the latest.
BTW, can you have more information for below reply?
RAXE500-(LAN or Wi-Fi)>GS716T->--(LAN or Wi-Fi)>pi-hole
I think it would be OK if GS716T connected with RAXE500 by LAN, but it will fail by WiFi- plemansMar 10, 2022Guru - Experienced User
Ethan_Kuo wrote:
Hi
1. The Device is notebook and service is FTP or http .---what device?
2. The router is connected with adsl modem.---what adsl modem?
3. The firmware of router is the latest.---and what version is that? the RAXE500's changes frequently.
BTW, can you have more information for below reply?---that's just what my current setup is.
I think it would be OK if GS716T connected with RAXE500 by LAN, but it will fail by WiFidetails are key to helping out. Not just general statements or models. If your mechanic asked you what vehicle you had you said "its a car" thats not enough to help.
Same with your nat statement. What specifically isn't being passed? what issue in detail are you having
Hi
To correct below information, the key point as red color.
1. Device <---LAN cable---> RAXE500(NAT) <---> ZyXEL VDSL2 p880 (Internet) (Pass)
2. Device <---WiFi---> RAXE500(NAT) <---> ZyXEL VDSL2 p880 (Internet) (Fail)
Here is my reply.
Thinkpad T480, Raspberry Pi4, synology NAS ( don't ask me any fw of those, it is not the key point)
2. The router is connected with adsl modem.---what adsl modem?ZyXEL VDSL2 p880
3. The firmware of router is the latest.---and what version is that? the RAXE500's changes frequently.FW V1.0.9.78_2.0.38
BTW, can you have more information for below reply?---that's just what my current setup is.As I mention before, your connection is by LAN cable to GS716T and then to RAXE500, right? if yes, it will be fine. BUT, with the same condition, just change your pi-hole connection to RAXE500 with "WiFi", it could be Fail on NAT function from internet. You can try it.
CM2000->RAXE500->GS716T->-->pi-hole
