Ethan_Kuo
Mar 02, 2022Tutor
RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN
Hi As subject (RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN). So, I would like to know the NAT is only support device connected with LAN cable? Here is my test...
- Mar 14, 2022
Dear all
The problem is solved by network setting cause by our internal gateway setting. (for special reason the setting of gateway is not same as DHCP server if unit want to connect to internet.)
and 2nd is check the ip in router (RAXE500) to make sure that can find it and the IP is correct.
Thanks.
Mar 10, 2022Guru - Experienced User
Ethan_Kuo wrote:
Hi
Thanks for your reply.
1. The Device is notebook and service is FTP or http .---what device?
2. The router is connected with adsl modem.---what adsl modem?
3. The firmware of router is the latest.---and what version is that? the RAXE500's changes frequently.
BTW, can you have more information for below reply?---that's just what my current setup is.
RAXE500-(LAN or Wi-Fi)>GS716T->--(LAN or Wi-Fi)>pi-hole
I think it would be OK if GS716T connected with RAXE500 by LAN, but it will fail by WiFi
details are key to helping out. Not just general statements or models. If your mechanic asked you what vehicle you had you said "its a car" thats not enough to help.
Same with your nat statement. What specifically isn't being passed? what issue in detail are you having
Ethan_Kuo
Mar 10, 2022Tutor
Hi
To correct below information, the key point as red color.
1. Device <---LAN cable---> RAXE500(NAT) <---> ZyXEL VDSL2 p880 (Internet) (Pass)
2. Device <---WiFi---> RAXE500(NAT) <---> ZyXEL VDSL2 p880 (Internet) (Fail)
Here is my reply.
Thinkpad T480, Raspberry Pi4, synology NAS ( don't ask me any fw of those, it is not the key point)
ZyXEL VDSL2 p880
FW V1.0.9.78_2.0.38
As I mention before, your connection is by LAN cable to GS716T and then to RAXE500, right? if yes, it will be fine. BUT, with the same condition, just change your pi-hole connection to RAXE500 with "WiFi", it could be Fail on NAT function from internet. You can try it.
CM2000->RAXE500->GS716T->-->pi-hole
- Ethan_KuoMar 10, 2022Tutor
Hi
I think it could be chip limitation of router, because ASUS RT-AC5300 FW 3.0.0.4.386 also have the same problem after I verified. It is so disappoint on NetGear RAXE500 and ASUS RT-AC5300 both expensive router. Hope they can see the topic and fix it in the futuer.
Thanks.
- plemansMar 10, 2022Guru - Experienced User
You still haven't said what you're trying to do.
You just keep saying nat isn't being passed.
What are you actually trying to accomplish?
And no, I can't put my pihole on wireless as its hosted in a docker container on my server.
Hi plemans
>> My purpose is let my notebook share the ftp or http to internet through NAT and connected with router by wifi not LAN cable.
>> My point is the NAT is work if notebook or NAS connect to router by LAN cable, But I want to using wifi not LAN cable to connect to router.
>> I have try the same condition and just change notebook connect with LAN to router is work, but connect with wifi to router is fail.
Thanks.
