Ethan_Kuo
Mar 02, 2022Tutor
RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN
Hi As subject (RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN). So, I would like to know the NAT is only support device connected with LAN cable? Here is my test...
- Mar 15, 2022
Dear all
The problem is solved by network setting cause by our internal gateway setting. (for special reason the setting of gateway is not same as DHCP server if unit want to connect to internet.)
and 2nd is check the ip in router (RAXE500) to make sure that can find it and the IP is correct.
Thanks.
Ethan_Kuo
Mar 11, 2022Tutor
Hi plemans
You still haven't said what you're trying to do
>> My purpose is let my notebook share the ftp or http to internet through NAT and connected with router by wifi not LAN cable.
You just keep saying nat isn't being passed.
>> My point is the NAT is work if notebook or NAS connect to router by LAN cable, But I want to using wifi not LAN cable to connect to router.
What are you actually trying to accomplish?
>> I have try the same condition and just change notebook connect with LAN to router is work, but connect with wifi to router is fail.
Thanks.
Altsai
Mar 14, 2022NETGEAR Expert
I guess this is talking about firewall rules to allow application via WAN port?
- Ethan_KuoMar 14, 2022Tutor
Hi Altsai
Maybe as your guess, but I did not enable any firewall in router.
Thanks.
- Ethan_KuoMar 15, 2022Tutor
Dear all
Thanks.
