Ethan_Kuo
Mar 02, 2022Tutor
RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN
Hi As subject (RAXE500 can not pass NAT device through WiFi, but it is ok if device through LAN). So, I would like to know the NAT is only support device connected with LAN cable? Here is my test...
- Mar 14, 2022
Dear all
The problem is solved by network setting cause by our internal gateway setting. (for special reason the setting of gateway is not same as DHCP server if unit want to connect to internet.)
and 2nd is check the ip in router (RAXE500) to make sure that can find it and the IP is correct.
Thanks.
Ethan_Kuo
Mar 13, 2022Tutor
Hi Altsai
Maybe as your guess, but I did not enable any firewall in router.
Thanks.
Ethan_Kuo
Mar 14, 2022Tutor
Dear all
Thanks.
