martyr444
May 04, 2021Apprentice
RAXE500 cannot get speeds over 1G even though I have 1.2G Internet
My Xfinity speeds just went up from 1G to 1.2GB. If I test my speeds hooked up to the RAXE500 Router it still only gives me the 1G. If I go straight to my Netgear CM2000 Modem I get the 1.2G. Plus my...
Razor512
May 04, 2021Prodigy
With a completely wired setup, you will not be able to get 1.2Gbps with your current setup. the reason is because the router only has 1 2.5GbE port, thus you cannot have both your laptoop using a 2.5GbE adapter, as well as the 2.5GbE connection from the modem. The rest of the ports are either 1 GbE max, or 2 gigabit if you have an adapter that does teaming such as LACP. Your current adapter does not support LACP as it is a single Ethernet jack device.
Because of those limitations, you will end up with a 1GbE bottleneck unless you use an Ethernet adapter that has 2 Ethernet ports and supports teaming or LACP.The reason for this is is that you are currently ending up with one of 2 setups.
- You either have the model connected to the 2.5GbE port, and your USB ethernet adapter connected to one of the other Ethernet ports on the router which top out at 1 gigabit.
- The second scenario with your current hardware is the modem connected to the 1GbE WAN port and your USB adapter connected to the 2.5GbE port, buth the modem is now stuck with the 1 gigabit bottleneck.
Getting around the limitation:
- Use a WiFi adapter such as the Intel AX200 or Intel AX210. ($15-17 for AX200, and around $25 for the AX210)
- Get an Ethernet adapter that supports LACP (Often needs a desktop PC as they are often PCIe cards)
martyr444
So plugging the CM2000 to the 2.5G Port on the RAXE500 doesn't provide those speeds for all the port? What use it then? Since it sounds like there is no way to get my Laptop Lan connected to utilize my 1.2G Xfinifty speed. I have a CM1200 Modem too and it is cabable of 2G speeds, could it work for this? It has 4 ports on it verses the 1 port on the CM2000. I confirmed the new speeds are real with speed test that now go up to 1.24G when I go from my Modem directly to the Laptop Killer E3100 USB-C 3.1 to RJ-45 2.5Gbps Ethernet Adapter. If none of that can work, are there any Routers with 2 ports that go over the 1G limit?
- Razor512May 04, 2021Prodigy
The CM1200 will work if you enable LACP on both the modem, and on the RAXE500, go to Advanced > Setup > Internet setup, and then set the mode to Multi-Gig Internet (1 Gbps + 1 Gbps)
Then you will connect the first 2 Ethernet ports fromm the CM1200, to the yellow WAN port, and the first Ethernet port of the RAXE500.
That should then establish a 2Gbps connection to the modem, and then the laptop will have a 2.5GbE connectionn to the router via the 2.5GbE port.
Just be sure that LACP is enabled on both the CM1200 and the RAXE500.
- martyr444May 04, 2021Apprentice
I enabled LACP on both the CM1200 and the RAXE500. Both of them say active when I check the LACP. The Nic still shows only 1G unless I plug the Laptop Nic to the 2.5G Port on the RAXE500. When I do that, the speeds drop to almost half on downloads. When I connect the Laptop Nic to one of the other RAXE500 ports I get my 1G speed. Any thng I'm missing?
- plemansMay 05, 2021Guru - Experienced User
I went back and read this a couple times.
do you have the CM2000 or the CM1200?
the CM1200 has 4x ethernet ports and supports LACP.
The CM2000 only has a 2.5g port and doesn't support LACP.
If you have the CM2000, you'd connect the RAXE500 to it through the 2.5g port and set it up in your internet settings to use that port. That'd give the ROUTER the full 1.2g speeds. But like Razor512 says, unless you have a computer that supports LACP to use the RAXE's LACP support, you won't get >1gig out of a single port. Not saying you can't use the full 1.2gig just not through to one device/connection. I've managed it with 2x devices connected. (940mbs on one and 200mbps on the other during concurrent usage).
I've got the same CM2000 + RAXE500
