stepnup
Feb 17, 2023Guide
RAXE500 connected on 6ghz, frequently stops serving internet, requires disconnect/reconnect
Strange behavior on 6ghz channel with multiple adapters. AX411, AX211, and AX210. I connect for a few hours then internet stops working. Still says I have internet (windows 11), but serving up ...
Feb 18, 2023Guru - Experienced User
What modem/gateway is it connected to?
Strange behavior. My RAXE500 is currently in router mode and I'm not having any 6ghz issues with my AX210.
- stepnupFeb 18, 2023Guide
Netgear CM2000 modem.
Yes, it is like internet gets frozen. Disconnect, reconnect fix it. If I switch to 5ghz, no probelm. On 6ghz it happens few times a day. Very close to router (20 feet) so interference no a problem. Strong signal. None of the other devices have connection problems when this adapter stops getting internet.
Rob
- plemansFeb 18, 2023Guru - Experienced User
leave WMM enabled
Is ipv6 enabled?
Have you tried a different 6ghz channel?
I just noticed wmm was only disabled on 2.4 and 5ghz. It apparently did not allow me to disable on 6ghz when I tried. I reenable on other channles.
I did try multiple 6ghz (PSC)channels.
No ipv6
