newmanme2
Jun 11, 2021Guide
RAXE500 Constant Internet drops requiring reboots
Hello Everyone, I took a leap of faith and ordered the brand new RAXE500 AXE11000 because I am a long time loyal Netgear cusatomer. For two days now I have to reboot the router at least once an ...
newmanme2
Jun 11, 2021Guide
Thank you for rersponding.
My apologies as I thought this was a part of the Netgear support team.
- Router - RAXE500 - AXE11000
- Firmware - V1.0.5.62_2.0.35
- ISP Modem - AT&T 5268AC
- The description of the problem: The internet drops every 15 minutes or so.
- WiFi continues to broadcast, just connected without internet notice
NOTE: I found an online article that said turning off the /Advanced Setup/"Traffic Meter". I had turned off the Traffic Meter and DHCP, and my connection solid on for over an hour. I have just turned DHCP back on and will be monitoring for a while to see if the problem is soley with a bug in the "Traffic Monitor"
Again, I apologize for lashing out here. I can't believe I purchased the most expensive new home router from Netgear and this is what I got, and most importantly Netgears support is not reachable. I am sure all of you are here to help and I promise to save my furry for the Netgear Support Team :)
Thanks
Matt
Jun 11, 2021Guru - Experienced User
That gateway from att is a modem/router combo device.
Cascading router is a recipe for issues.
have you tried the RAXE in access point mode and disabling the wifi on the ATT device?
That prevents the double nat.
- newmanme2Jun 14, 2021Guide
Good morning
It does appear that the ATT modem was causing issues. Was it the whole problem, I do not know.
I now have the RAXE500 in its final location behind an enterprise class firewall. I still have IPv6 off, I have no need for IPv6 in my network. And the traffic meter is turned off.
As for trying the unit in AP mode, that would be a waste of money for a full blown router. If I cannot successfully get this router to work as a router, then I will send it back as a very unhappy Netgear customer.
Right now the RAXE500 is behaving. Lets see what the next 24 hours bring. I will keep updating things here so others can look for information that might help them also.
I will say this, Netgear is lucky I am a loyal and well versed IT engineer as regular uses are not going to have the technical experience to fix these issues.
For the Netgear team is they are monitoring:
If anyone from Netgear is monitoring these chats, PLEASE FIX THESE ISSUES AND GET NEW FIRMWARE OUT! Relasing a new piece of equipment with issues like this does not say anything good about "your" loyalty to your customers. Your support link is still down after 5 days.
Thanks
Matt
