lvchen860217
Mar 11, 2022Guide
Raxe500 crashes occasionally after upgrading to FW 1.0.9.78
I have been using the RAXE500 for several months and it is very stable. Since it was updated to 1.0.9.78, it began to crash / restart occasionally two weeks after startup. The crash shows that all wi...
Mar 11, 2022Guru - Experienced User
If you're having issues, you can downgrade the firmware.
Better to have a stable device than one with a few different bug fixes.
I know there's another firmware in the works but I don't know if it addresses the issue you're having.
