ShadowMario3's avatar
ShadowMario3
Luminary
Apr 20, 2022
RAXE500 Daily Logs Not always working
I am having a similar issue to this topic: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAXE500-email-router-logs-daily-hourly-not-working/m-p/2090338   I am on Firmware Versio...
  • FURRYe38's avatar
    Any progress on this?
    Have you tried the newest FW version to see if this is fixed?
    ShadowMario3 wrote:
    Thanks for checking it out, completely missed your suggestion for debugging. As for the ONT I am using, I am unfortunately unable to check it since it's hidden behind a hard to reach area at the moment. The ISP is GoNetSpeed, so it's whatever they offer for fiber.
    As for the day and time options being greyed out when you are set to hourly, I'm pretty sure that is normal because hourly is supposed to send a log at the top of the hour no matter what.
