ShadowMario3
Apr 20, 2022Luminary
RAXE500 Daily Logs Not always working
I am having a similar issue to this topic: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAXE500-email-router-logs-daily-hourly-not-working/m-p/2090338 I am on Firmware Versio...
- Dec 06, 2022
Any progress on this?
Have you tried the newest FW version to see if this is fixed?
ShadowMario3 wrote:
Thanks for checking it out, completely missed your suggestion for debugging. As for the ONT I am using, I am unfortunately unable to check it since it's hidden behind a hard to reach area at the moment. The ISP is GoNetSpeed, so it's whatever they offer for fiber.
As for the day and time options being greyed out when you are set to hourly, I'm pretty sure that is normal because hourly is supposed to send a log at the top of the hour no matter what.
Stappmeyer
Aug 25, 2022Aspirant
I have a new RAXE500 and I am seeing this issue. Did you have a resolution or workaround? Firmware v1.0.10.86_2.0.40
ShadowMario3
Aug 26, 2022Luminary
After firmware V1.0.10.82, it seemed to be behaving consistently as long as I set it to hourly logs. I made sure to set up the sender with a gmail account (used an app password due to 2FA). After that was done, rebooting the router made hourly logs consistent. I noticed that changing any setting (email setup, Address reservation, NTP sync) would throw it off again, so after changing the setting, I would have to reboot the route to get the logs to sent consistent emails.
- FURRYe38Aug 26, 2022Guru - Experienced User
What is happening exactly when email logs are working then you make a change as you mentioned? Are the logs failing to be sent or do the log contents not look right?
- ShadowMario3Aug 26, 2022Luminary
After I make a change, they eventually fail to be sent with this error:
[email failed] internet connection is dropped
After a few hours, one hourly log manages to be sent, but they eventually constantly fail until I reboot the router. The "internet connection is dropped" error occurred when I had internet set to DHCP through Comcast and after I switched over to a new ISP with a static IP.
Would you enable Debug logging under router IP address/debug.htm after a reboot and email logs are enabled to fail and when they do, go in and save off the debug logs please?
Has a factory reset been performed since last FW update?
