Smuuth's avatar
Smuuth
RAXE500 Delete Log of threats blocked?
I recently purchased this router and I am very pleased, however, My ISP was recently down and when service was returned, the router blocked what it thought were multiple DDOS attacks. Evidently something with the initial restart of my connection caused the issue. My question: Is there any way to clear or delete the log of threats deleted?
Thanks for any help you can provide.
    Are these entries that you saw on the logs?
    Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
    Search - NETGEAR Communities – DoS attacks
    Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
    Here is a useful tool for that task:
    IPNetInfo: Retrieve IP Address Information from WHOIS servers
    If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
  • FURRYe38's avatar
    Should be a Clear Log button that you can select under Logs
    • Smuuth's avatar
      Smuuth
      Thank you, I found that and cleared the log but it all still shows up in the Netgear Nighthawk app.
  • michaelkenward's avatar
    michaelkenward
