Mike-F
Apr 14, 2022Initiate
RAXE500 DHCP Address reservation issues
Hi, All. I'm an IT Professional of 20+ years. I've never had this issue with any router I've ever used, and I'm totally stumped on how to fix it. I just bought this router a few weeks ago, and al...
Mike-F
Apr 16, 2022Initiate
I have 18 reservations in total. As you can tell, I have an elaborate home network. The weird thing is that the reservation dropping is random. It drops my reservations for the 8th, 9th and then the 12th through 17th reservations. All the other ones are fine. It's really bizarre. Even then, it assigns addresses in the 2xx range (not the 26 where DHCP is supposed to start).
I've tried switching over to 192.168.1.X, and I've had issues there as well. During the reboot process, a bunch of devices (mainly WiFi light bulbs) will still have the 192.168.0.X address and are showed in Attached Devices. I really wish these routers had the ability to end the DHCP lease manually (Hint, Hint NetGear!).
I've also tried changing the pool from using 192.168.0.26 through 254 to 100 (hoping that it would shake everything up). It didn't. Devices (wired and wireless) still showed up in the .200 range even after that.
My fix so far is manually changing the address to static (shame on you, NetGear). I'm going to change them back to DHCP after 24 hours have elapsed hoping that the router will reassign them to what they should be after their leases are up. Unfortunately I can't do this with all the devices (I have 3 SiliconDust HDHomeRuns (2 (4 tuners) and 1 (2 tuner)). and it's just killing me that the 4 tuner versions are .12 and .13, with the Duo being .234.
I'm disgusted that Netgear let this router out with so many issues. I've had a issue with my Synology DS918+ and Link Aggregation on this router as well. (I just gave up and set up LACP on my GS324T (and it took two seconds)). It worked PERFECTLY on my R9000 (my previous router). Like I said, I've always used Netgear, and they just disappoint more and more. I'm buying a Protectli Vault to do end-to-end encryption, and if this is still the issue, I'm going to use this router for WiFi6, and have the Protectli dish out addresses.
Any other ideas, or any new things to try? You were saying that a newer firmware is coming out soon. Maybe this will address this?
