madger
Sep 30, 2022Tutor
RAXE500 Disappointing
Raxe500 Firmware Version V1.0.10.86_2.0.40 I have 2 gigabit fiber ATT internet with the BGW320-500 modem in passthrough. Cat 7 cable plugged into the 5gb ethernet port on the BGW320 going to the 2....
Oct 01, 2022Guru - Experienced User
A couple things.
1. did you check to see if the wan port was connecting at the 2.5gig connection?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
2. Even though the router has a 2.5gig port, it only has 1x. So if you're modem is using the 2.5gig port, the other hardwired devices are using the 1gig ports (unless your using lan port aggregation). So those hardwired devices will max out at the 1 gig
3. when speedtesting wireless, did you try other channels on the 5/6ghz? Plus you need to be close to it as those speeds will drop off quickly.
4. Is the ATT gateway in passthrough/modem only mode? Or are you in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
madger
Oct 01, 2022Tutor
This what the statistics show, i have double checked passthrough. and wan 2.5 port ip and mac are set in bgw320.
all firewall in bgw320 is disabled except packet filtering. should i disable that?
Show Statistics |
System Up Time 17:08:18
| Port | Status | Tx | Rx | Collisions | Tx B/s | Rx B/s | Up Time |
| WAN(Multi-Gig Port) | 2500M/Full | 13660615 | 16347580 | 0 | 277140 | 261568 | 13:51:58 |
| LAN1 | 1000M/Full | 606120 | 427432 | 0 | 8009 | 890 | 17:06:19 |
| LAN2 | 1000M/Full | 1562280 | 3105671 | 0 | 4449 | 52633 | 17:06:20 |
| LAN3 | 1000M/Full | 593120 | 351395 | 0 | 2536 | 6235 | 17:06:21 |
| LAN4 | 1000M/Full | 409534 | 6733 | 0 | 1529 | 7 | 17:06:22 |
| LAN5 (Internet Port) | Link Down | -- | -- | -- | -- | -- | -- |
| 2.4G WLAN b/g/n/ax | 1200M | 2813889 | 6556298 | 0 | 8267 | 97956 | 17:08:18 |
| 5G WLAN a/n/ac/ax | 4800M | 12600547 | 8426458 | 0 | 269053 | 122285 | 17:08:18 |
| 6G WLAN ax | 4800M | 308662 | 0 | 0 | 1032 | 0 | 17:08:18 |
- plemansOct 01, 2022Guru - Experienced User
Have you tried leaving the BGW in router mode (disable its wifi) and put the netgear in AP mode? I've seen their passthrough mode not work properly and att has zero motivation to fix it.
