madger
Sep 30, 2022Tutor
RAXE500 Disappointing
Raxe500 Firmware Version V1.0.10.86_2.0.40 I have 2 gigabit fiber ATT internet with the BGW320-500 modem in passthrough. Cat 7 cable plugged into the 5gb ethernet port on the BGW320 going to the 2....
madger
Oct 01, 2022Tutor
This what the statistics show, i have double checked passthrough. and wan 2.5 port ip and mac are set in bgw320.
all firewall in bgw320 is disabled except packet filtering. should i disable that?
Show Statistics |
System Up Time 17:08:18
| Port | Status | Tx | Rx | Collisions | Tx B/s | Rx B/s | Up Time |
| WAN(Multi-Gig Port) | 2500M/Full | 13660615 | 16347580 | 0 | 277140 | 261568 | 13:51:58 |
| LAN1 | 1000M/Full | 606120 | 427432 | 0 | 8009 | 890 | 17:06:19 |
| LAN2 | 1000M/Full | 1562280 | 3105671 | 0 | 4449 | 52633 | 17:06:20 |
| LAN3 | 1000M/Full | 593120 | 351395 | 0 | 2536 | 6235 | 17:06:21 |
| LAN4 | 1000M/Full | 409534 | 6733 | 0 | 1529 | 7 | 17:06:22 |
| LAN5 (Internet Port) | Link Down | -- | -- | -- | -- | -- | -- |
| 2.4G WLAN b/g/n/ax | 1200M | 2813889 | 6556298 | 0 | 8267 | 97956 | 17:08:18 |
| 5G WLAN a/n/ac/ax | 4800M | 12600547 | 8426458 | 0 | 269053 | 122285 | 17:08:18 |
| 6G WLAN ax | 4800M | 308662 | 0 | 0 | 1032 | 0 | 17:08:18 |
Oct 01, 2022Guru - Experienced User
Have you tried leaving the BGW in router mode (disable its wifi) and put the netgear in AP mode? I've seen their passthrough mode not work properly and att has zero motivation to fix it.
