perseid
Oct 09, 2022Aspirant
RAXE500 displays as a drive under Network Locations/Windows Explorer
Randomly I see the RAXE500 show up as a folder under Network Locations in Windows Explorer and if I click on it a bunch of folders open up as shown in attached picture. Any way to disable this sharin...
- Nov 26, 2022
If you log in through the router and go to advanced--->usb functions---> and then uncheck the readyshare features, does that disable it for you?
Oct 09, 2022Guru - Experienced User
Do you have a usb drive connected to it?
- perseidOct 09, 2022Aspirant
Hi, no, that's the weird side, I don't have any USB or external drive connected to the RAXE500. I only have the RAXE500 as an AP wired to the main wired router
- perseidNov 25, 2022Aspirant
Any idea as to how to disable the RAXE500 network folder? When I click on it this is the structure:
- plemansNov 26, 2022Guru - Experienced User
