Mahesh_Wireless
May 11, 2023Aspirant
RAXE500 DTIM Settings
I have RAXE500 Router and want to configure router's DTIM settings to different values (2, 3 etc) for testing. Please share the steps to change the DTIM settings on this router. I don't see any sec...
michaelkenward
May 12, 2023Guru - Experienced User
Why do you want to do that?
Maybe there are other ways of achieving what you want.
- Mahesh_WirelessMay 12, 2023Aspirant
I am performing certain tests on device side behavior when connected to routers at different DTIM intervals. By default routers come with DTIM set to 1. I want to change it to 2 or 3 and perform tests on connected device side
- FURRYe38May 12, 2023Guru - Experienced User
I remember seeing this on older generation routers from say 15+ years ago. I think its' mostly a automatic feature now that something isn't needed to be adjusted on home class routers anymore thus NG and others have removed that UI since so not supported as a UI feature anymore.
