RottenMutt
Jun 02, 2023Aspirant
RAXE500 Firmware 1.0.12.96 Access point mode lose ability to connect to admin page
RAXE500 Firmware 1.0.12.96 Access point mode lose ability to connect to admin page. After about 4-5 months after resetting router and reconfiguring the router I lose the ability to access the admin ...
Jun 02, 2023Guru - Experienced User
What is the brand and model# of the host router the RAXE is connected too?
What version of NH app are you using?
What mobile device are you using?
Be sure any MAC address randomizers are disabled while at home:
How is the AP mode configured on the RAXE? Dynamic or Static configuration? I recommend static so you know where the IP address is and doesn't change. I use .50 on mine while in Bridge mode. Should be able to do same thing in AP mode.
I presume RAXE web UI is accessible?
Maybe submit a bug report?
RottenMutt
Jun 04, 2023Aspirant
Raxe500 is connected to clear os server/gateway. I had it set to a static address (192.168.0.100) but it changed the address on its own. So static configuration don’t work, now I have it set to dynamic.
firmware needs to be fixed. This was supposedly fixed in earlier firmware version, but I guess not.
can this thread be moved back to the RAXE500 NIGHTHAWK category/sub…
- FURRYe38Jun 05, 2023Guru - Experienced User
If you configure AP mode on the RAXE and set a static configuration for the AP mode on the RAXE, be sure that the static IP address is out side of the host routers default DHCP IP address pool range. Static IP addressed devices should be outside of this range, not with in it.
