RottenMutt
Jun 02, 2023Aspirant
RAXE500 Firmware 1.0.12.96 Access point mode lose ability to connect to admin page
RAXE500 Firmware 1.0.12.96 Access point mode lose ability to connect to admin page. After about 4-5 months after resetting router and reconfiguring the router I lose the ability to access the admin ...
RottenMutt
Jun 04, 2023Aspirant
Raxe500 is connected to clear os server/gateway. I had it set to a static address (192.168.0.100) but it changed the address on its own. So static configuration don’t work, now I have it set to dynamic.
firmware needs to be fixed. This was supposedly fixed in earlier firmware version, but I guess not.
can this thread be moved back to the RAXE500 NIGHTHAWK category/sub…
Jun 05, 2023Guru - Experienced User
If you configure AP mode on the RAXE and set a static configuration for the AP mode on the RAXE, be sure that the static IP address is out side of the host routers default DHCP IP address pool range. Static IP addressed devices should be outside of this range, not with in it.
