pjd813
Apr 15, 2023Guide
RAXE500 firmware update?
I received an email from Netgear saying that there was an important security update available for my model. I tried to update my RAXE500 router from firmware version xx.xx.86.xx to xx.xx.96.xx It t...
- Apr 15, 2023
DO NOT attempt to open the .chk file in Mac OS. The file gets used and sent down thru the routers WEB UI page. Open the routers WEB UI page in a web browser and send the .chk file there.
pjd813 wrote:
Hi,
When I do the download I get a zip file that has two files; 1) an HTML file that takes me to a page that describes the update and 2) a file with a .chk extension and my Mac says it has no application to open that file type.
pjd813
Apr 15, 2023Guide
Hi,
michaelkenward
Apr 15, 2023Guru - Experienced User
Read the release notes.
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAXE500.aspx#docs.
Also:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- pjd813Apr 15, 2023Guide
The references I see to the current update show a large number of fixes. Even if many are inconsequential I’m always interested in the security updates. I’ve tried all of the solutions mentioned here and I am at the point where I get “no update is available” no matter the web UI or the app messages - or the .cfg file I mentioned earlier. Since I didn’t save the settings prior to the update I guess I’m just hosed until the next update.
