kpaskevicius
Mar 13, 2023Aspirant
RAXE500 frequent device drops in house
I'm having a timely issue where my new RAXE500 keeps dropping my family's connection. We originally used xfinity gateway with xfinity pods, which is outperforming this RAXE500 and AX6000 x2 extende...
Mar 13, 2023Guru - Experienced User
What modem/gateway do you have it connected to?
You have 2x extenders? what size is the home? I usually don't recommend using more than 1 extender and if you do need more than 1, a mesh system is a better choice (like the xinfity) as there's something controlling it.
Not so when using mesh extenders.
What firmware is on the router?
And on the extenders?
Does it stay stable if you power off one of the extenders?
kpaskevicius
Hardware Version RAXE500
Firmware Version V1.0.10.86_2.0.40
Hardware Version: EAX80
Firmware Version: V1.0.1.70_1.0.2
I recently have tried to get the fast lane on extenders going.
3 floors, awkward house design.
as a side note again, xfinity pods were fine for my family originally.
The fast lane is supposed to be using both 5ghz and 2.4 together , looks like improving speed tests.
But the main problem is still the soft disconnects, making family have to sign back in.
Mobile devices don't seem to be connected to the extenders directly when I review the connected devices on the app.
Extenders are closer to more people.
RAXE500 . Devices online (17)
EAX80 Devices online (3)
EAX80 Devices online (1)
- plemansMar 13, 2023Guru - Experienced User
Problem with the extenders is they can end up connecting to each other.
You'd want them set up so the router is in the middle in a star configuration
extender<--------router-------->extender
And I'd try powering on off and testing the system.
You can get the behavior you're seeing if they end up connecting to each other and not the router.
Also, fastlane dedicates one of the bands (either 2.4ghz or 5ghz) for router----extender communication and then uses the other band for extender-----devices.
- kpaskeviciusMar 13, 2023Aspirant
I attached a jpg of my router setup on my netgear app. is that correctly in the middle? or is there another way?
- michaelkenwardMar 13, 2023Guru - Experienced User
Did you ever say what sits between the RAXE500 and the Internet?
or is there another way?It depends on the layout of the house and the distance been these things.
If the router is in the middle of the house and those extenders are between it and the extremities, that would work, but if the router is at one end of the house, then "daisy chained", with one between the router and the other one, can work better.
As plemans says, one extender might be better, depending on the layout. Three floors doesn't say much about the distance between them. If the router is on the ground floor, then a single extender on the second floor might work.
Extenders are best put somewhere between the router and the edge of the property. There's no point in putting them near the outside walls or on the top floor, unless you want to serve the neighbours, or want WiFi in the garden.
Have you experimented with that layout?
