Giddleytwig
Nov 27, 2022Tutor
RAXE500 has two 6e networks that are not guest
Hello, I just setup a RAXE500 router with a CM2000 modem and noticed that there are by default on my samsung android phone a 2.4 and 5 GHz networks like there should be. But for the 6e network i ...
Nov 27, 2022Guru - Experienced User
1. there's a newer firmware 1.0.11.94 you can try installing that and doing a factory reset/reinstall.
2. what happens if you enable smart connect?
3. Do you have a screen snip of something like inssider that actually lets you look at the networks and the details?
Giddleytwig
Nov 27, 2022Tutor
1. I will do that for sure later today. Currently away from home.
2. Again I will let you know later today what happens.
3. I will get one once I do the firmware update and will post it.
