JoeRMV
Nov 20, 2023Aspirant
RAXE500 Intermediate dropping (all channels) & 5g channel disappearing
Over the past week, my relatively new RAXE500 Nighthawk started to drop signals. I know it is the router vs my provider since this has occurred while I was using Apple TV which is connected via ether...
JoeRMV
Nov 28, 2023Aspirant
Thanks for the advice. I checked to be sure I had the most current firmware. Every time I would use the app, it said my firmware was up to date. That didn't seem right since it has been over a year since I recall any updates. I went online to see the most current version and realized mine was old (v1.0.10.86). I downloaded the most current firmware (v1.0.12.96) on my Mac and then forced the update. That was a couple days ago. I haven't noticed any drops yet. I did notice a slight reduction to my internet speeds of 940 up and 940 down. I have seen 3-30% reduction to max speeds especially the download speeds. Before the update, my speeds were always the max of 940 & 940 (sometimes slightly above).
Nov 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
I'd factory reset and setup from scratch afterwards.
Be sure to test speeds with a wired PC first soon after the factory reset. Don't enable any Armor, Access Controls or Traffic meter. Be sure to set up with a web browser: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 10 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
