ikaney
Apr 02, 2024Initiate
RAXE500 IPv6 issues with Zen Internet UK
Firmware Version V1.2.13.100_2.0.54 I'm attempting to setup my router with IPv6 on Zen Internet in the UK. They've provided the following information: - The WAN interface should use native DH...
Apr 02, 2024Guru - Experienced User
Which port are you using on the RAXE for the connection to the ISP modem/ONT? Yellow internet port or the multi gig port?
Check the router logs for any IPv6 errors there.
Does the DHCP/6to4 work?
Contact the ISP and have them help you configure the IPv6 settings.
Be sure to test IPv6 configuration with IPv6 testing sites:
