ikaney
Apr 02, 2024Initiate
RAXE500 IPv6 issues with Zen Internet UK
Firmware Version V1.2.13.100_2.0.54 I'm attempting to setup my router with IPv6 on Zen Internet in the UK. They've provided the following information: - The WAN interface should use native DH...
ikaney
The 6to4 tunnel didn’t use the correct IPv6 block I was assigned and failed on the IPv6 test site.
It’s passing the tests with my current setup but as I said the prefix being handed out is wrong.
ONT I think is Nokia, using the multi-gig port.
Zen have said they can’t really assist with setup apart from the information they sent over.
Apr 02, 2024Guru - Experienced User
There a model# of the Nokia?
Others have posted having issues on this version of FW. We've passed this onto NG for review as well. I'd revert to previous version of FW, factory reset the router and setup from scratch and then try DHCP IPv6 again. If this fails, you'll need to open up a support ticket with NG support.
