Yousef
Oct 04, 2024Guide
RAXE500 Issues
Hi,
i found multi bugs need to be solved with RAXE500, first of all last version update is still very buggy, and will show the bugs with pic,
first of all when the connected device reached more than 64 devices it will show in router login page required reset passwords once the devices less than 64 it will be freely open,
secondly
even the stable versions still have an issue with duplicated local IP and i need to keep it static ip to make sure the devices can connected without any issue even the phones.
the last update is not stable and have the following issues:
1- login to router page will be disabled like the page is not opening at all and required router restart to be able to login in again.
2- slow surfing the internet and unstable internet connection.
3- WIFI 6e not connected at all 5 GHz and 2.4 working normally as this router should be WIFI 6e.
the best FW stable version can be used with less bugs is 1.0.12.96 WIFI 6e working fine , the newer totally not usable.
kindly note those kind of bugs not a new and it was since last buggy FW released and it was ignored since then.
please advise.
1 Reply
