strykerzr350
Apr 24, 2022Guide
RAXE500 LEDs not blinking using the 2.5GBE port
I have my modem connected using the 2.5GBE port and the internet LED, wifi LEDs do not blink while using this as my preferred WAN connection. Is this a bug or UI issue? They seem to blink fine on the...
Apr 24, 2022Guru - Experienced User
What CAT# LAN cable are you using? I recommend using CAT6A STP cable when connected to the 2.5Gb port.
strykerzr350
Apr 24, 2022Guide
I am using a Cat6 cable I never use the ones that come with modems. The modem I am using is a Netgear CM2000.
Everything is fine with the modem and the router.
Just the LEDs do not blink when using the 2.5GBE port for the WAN connection. Only ones that blink is the ones for the 1Gbps ports.
I am also running the latest firmware for the RAXE500.
