strykerzr350
Apr 24, 2022Guide
RAXE500 LEDs not blinking using the 2.5GBE port
I have my modem connected using the 2.5GBE port and the internet LED, wifi LEDs do not blink while using this as my preferred WAN connection. Is this a bug or UI issue? They seem to blink fine on the...
Apr 24, 2022Guru - Experienced User
What CAT# LAN cable are you using? I recommend using CAT6A STP cable when connected to the 2.5Gb port.
strykerzr350
Apr 28, 2022Guide
Swapped over the connection to the regular LAN port and nothing blinks other than the port LEDs for ports 1 to 4. So I dont know what the problem is.
The manual says that the internet LED, wireless LEDs and port LEDs will blink but they are all static.
- MitcherApr 29, 2022Guide
strykerzr350 - I have a RAXE500. Only ports 1-5 blink. The others are static. I believe that has always been the case regardless of my firmware version. Maybe the manual is wrong?
Thanks,
Mitch
- strykerzr350Apr 30, 2022Guide
I am running the current firmware and the manual must have taken information from older routers. Netgear should fix this as you need to know if someone is using wifi in your house.
Not really sure if firmware or hardware is a limiting factor.
