strykerzr350
Apr 24, 2022Guide
RAXE500 LEDs not blinking using the 2.5GBE port
I have my modem connected using the 2.5GBE port and the internet LED, wifi LEDs do not blink while using this as my preferred WAN connection. Is this a bug or UI issue? They seem to blink fine on the...
Apr 28, 2022Guru - Experienced User
Have you factory reset the router, powered OFF the router by pulling the power plug from behind the router for 10 seconds then back in and then setup from scratch?
