mshasib
Jun 26, 2021Aspirant
RAXE500 Link Aggregation Not Working
I purchased a Netgear RAXE500 recently and I'm on the latest firmware (V1.0.5.62_2.0.35). I am unable to setup link aggregation on. I have tried both static and LACP mode using a Netgear and a TP...
Razor512
Jun 27, 2021Prodigy
On your switch, did you enable LACP on the 2 ports that you have connected to the router? Both the router and the switch must have LACP enabledd otherwise you will run intl an unusable connection.
- mshasibJun 28, 2021Aspirant
Yes, obviously. I setup LACP on both the router and the switch and then connected the cables on both ports.
- Christian_RJul 02, 2021NETGEAR Employee Retired
Hello mshasib,
Have you had a moment to reach out to our support team regarding this? Newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/contact.aspx
Christian
- mshasibJul 02, 2021Aspirant
Hi Christian_R ,
A case has been open since 05/18/21. Unfortunately, there is still no resolution on this.
I am surprised that support has not been able to provide me a solution in spite of both my devices being Netgear.
I would appreciate if you can escalate the case.
