mshasib
Jun 26, 2021Aspirant
RAXE500 Link Aggregation Not Working
I purchased a Netgear RAXE500 recently and I'm on the latest firmware (V1.0.5.62_2.0.35). I am unable to setup link aggregation on. I have tried both static and LACP mode using a Netgear and a TP...
Razor512
Jun 27, 2021Prodigy
On your switch, did you enable LACP on the 2 ports that you have connected to the router? Both the router and the switch must have LACP enabledd otherwise you will run intl an unusable connection.
mshasib
Jun 28, 2021Aspirant
Yes, obviously. I setup LACP on both the router and the switch and then connected the cables on both ports.
- Christian_RJul 02, 2021NETGEAR Employee Retired
Hello mshasib,
Have you had a moment to reach out to our support team regarding this? Newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/contact.aspx
Christian
- mshasibJul 02, 2021Aspirant
Hi Christian_R ,
A case has been open since 05/18/21. Unfortunately, there is still no resolution on this.
I am surprised that support has not been able to provide me a solution in spite of both my devices being Netgear.
I would appreciate if you can escalate the case.
- Christian_RJul 06, 2021NETGEAR Employee Retired
Hello mshasib,
May you provide me with your case number and I'll reach out to our support teams.
Regards,Christian
