mshasib
Jun 26, 2021Aspirant
RAXE500 Link Aggregation Not Working
I purchased a Netgear RAXE500 recently and I'm on the latest firmware (V1.0.5.62_2.0.35). I am unable to setup link aggregation on. I have tried both static and LACP mode using a Netgear and a TP...
joaos
Jul 06, 2021Tutor
I have LACP multi-gig (1 + 1) working on WAN side, connecting to an Arris modem, with no problem at all, but I had not tried the LAN side as it seems to be your case. Setting up the switch for link aggregation may be a little tricky though. If you have other hardware that supports LA (like NAS, for example), I would give it a try, just to discard the possibility that the problem might be with the router.
Latest firmware is V1.0.6.64, did you upgrade already?
- Razor512Jul 06, 2021Prodigy
With some managed switches, it can get tricky getting LACP working right, especially when they offer a ton of different methods and hashing types, where it could end up requiring some trial and error.
TP-Link tends to offer a bunch of options on their managed switches for hash algorithm, number of ports used, passive or active LACP, etc.
