Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
TWilson
Feb 15, 2023Aspirant
This may be the first report of this that you've seen but according to Netgear's own release notes for Firmware 1.0.12.96 there is a known 2.4 GHz connection issue with it. The 1.0.12.96 firmware release notes clearly state:
Known Issues:
- The Nighthawk app and router web interface don’t successfully complete the OOKLA speed test in PPPoE mode, but the speed test does work normally if you run it from the OOKLA web portal or OOKLA app.
- Clients cannot connect to the 2.4 GHz band if it functions with a 40 MHz channel width.
My 2.4GHz band with current settings has been rock solid since I purchased this router in 2021. This problem appeared within hours of updating to this firmware version and has been re-occurring every few days since after having been restarted to fix. I've reset it to factory defaults and manually reconfigured to no avail.
I'll roll back to the prior version this coming weekend.
Killhippie
Feb 19, 2023Prodigy
Just turn 2.4Ghz to 20Mhz which unless you live in the middle of a field you wont get any benefit from running at 40Mhz anyway. Also most clients tend to support 20Mhz anyway more so IoT devices, it will just cause increased noise levels, less throughput and more interference on your own network let alone your neighbours. Considering the amount of bug fixes in this release plus security updates I think dropping back to 20Mhz is perfectly acceptable, last night I watched a 15Gb film to my Sky Q box over 2.4Ghz (wont use 5 or 6Ghz unless you use Sky as your provider which I don't) and had no issues steaming whatsoever at 20Mhz.
