Killhippie
Jan 02, 2023Prodigy
RAXE500 New Firmware 1.0.12.96 released
BugFixes: 01/02/2023
Fixes the issue where a configuration through the router web interface causes a port conflict.
Fixes the issue where the router web interface shows that the guest WiFi netw...
Mar 04, 2023Guru - Experienced User
You can try them all one then disable the ones you may not need or use or seems to cause problems. Most newer devices in past few year should all support MIMO so you can enable this and see.
phrostb
Mar 04, 2023Star
So there's no particular combinations I should be weary of? I wonder why Netgear is disabling some of these "premium" features by default. Seems a bit strange.. anyway, thanks for your advice friend!
